            1130C Ethernet
                ports 1 - 4 are 1 GbE RJ45 ports. Ensure that the device to be connected at the
                other end of the segment is powered on.
            To connect a twisted pair cabling:
                Connect the twisted pair segment
                    to the appliance by inserting the RJ45 connector on the twisted pair segment
                    into the desired RJ45 port.
                Verify that a link exists by
                    checking that the Activity Link LED is On (solid green or blinking green).
                 If the Activity Link LED is off, perform the following steps until it is
                    On:
                        - Verify that the cabling
                            being used is Category 5 or better, with an impedance between 85 and 111
                            ohms and a maximum length of 100 meters (328 feet).
- Verify that the device at
                            the other end of the twisted pair segment is turned on and is properly
                            connected to the segment.
- Verify that the RJ45
                            connectors on the twisted pair segment have the proper pinouts, and
                            check the cable for continuity.
                If a link is not established,
                    contact Extreme Networks Support.
